well, I have learned ALOT since registering here and have gotten to a point wherei can't find an answer
I have matched up my audio and a friends video for a band we work for into a 11GB total .avi file with great vid picture quality...
1what program do you recomended using to convert to DVD?
TMPEC looks pretty bad so???
2also, will going from avi>MPEG degrade the quality?
3 and finally, is there an .avi shrink program or should I take the converted MPEG and run it through DVDshrink?
thanks so much for this forum and if you ever need any live audio recording or mixing help, I'm your man
tim
What is the running time of the video?
Stick that in the Bitrate Calculator and see what bitrate you come up with.Cheers, Jim
My DVDLab Guides -
This is the average bitrate you can use for the VIDEO portion of the encode. The AUDIO portion is 224kbps.
That is a very high average, and I wouldn't go over 8000, or your standalone player may not play it.
With the right settings in tmpgenc, you should end up with a really nice DVD.Cheers, Jim
My DVDLab Guides -
1) TMPGEnc is not bad at encoding to DVD mpeg.
2) Yes, since mpeg2 is not a lossless format, quality will degrade. The thing is to minimize the quality loss.
3) It's always better (if we're talking about quality) to encode at the right bitrate to begin with, than encoding to a (for the storage media/format) too high bitrate, and then shrink it to fit. Shrinking the AVI would be pointless, as source file size is irrelevant - only length (in time) matters.
/Mats
Preserving image quality from flash camcorder to dvd?
By rsud in forum Authoring (DVD)Replies: 7Last Post: 19th May 2010, 17:57 -
AVCHD to DVD preserving widescreen and as much quality as possible
By jstemper in forum Newbie / General discussionsReplies: 6Last Post: 16th Sep 2009, 20:27 -
Best way to convert VHS to digital while preserving quality?
By Jabroni4872 in forum Video ConversionReplies: 2Last Post: 8th Oct 2008, 01:59 -
preserving quality in DVD (HD) authoring (matroska)
By pay1000 in forum Authoring (DVD)Replies: 11Last Post: 22nd Jul 2008, 09:20 -
MPG to DVD / preserving audio quality
By tempgal in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2007, 12:09
