This is what I call a 'Scratch Guide', that means I assume you are already competent with using the tools listed, or their use has been well documented already on the Videohelp.com site. Definitely NOT for beginners.
Tools needed:
1 Nokia N-Gage QD (obviously)
Smartmovie (from Lonely Cat Games)
XVid Codec for PC
XVid Codec for Symbian S60 (from Lonely Cat Games)
EasyVCD
Nokia PC Suite (for N-Gage QD)
AudioDub 1.5 or greater.
A DVD of your favourite movie
First off, if you have installed Realplayer, uninstall it and get yourself Lonely Cat Games Smartmovie Player (You dont need the PC Converter - this way is better) and the XVID Codec for your N-Gage QD (available from the Lonely Cat Games site). You also need a MMC card with 128Mb free for your movie to go on.
Use EasyVCD to rip your movie to an XVCD on 1 CD, MPEG file only
This took 1 1/2 hr on my 2.2 Gig laptop.
Load MPEG into AudioDub
Compress audio using MP3 16bit @ 16000Hz Mono
Reduce Video Frames to 15 if NTSC film, 12 if PAL film
Resize Video to 176x144
Compress Video using XVID or DIVX (I prefer DIVX for a smoother judder free movie)
Save AVI file
This took 2 min on Laptop
Transfer movie to N-Gage QD root directory of MMC card using PC Suite (this took over 20 minbluetooth is sloooooow)
Run Smartmovie Player on N-Gage, go to browse files and play your movie!!!
Stats:
Original DVD of Bruce Almighty 9Gig
Smartmovie DIVX file 71Mb, better quality than Realmedia equivalent
N.B.
Do not use 'div3', it doesn't work on my N-Gage QD - 'divx' or 'xvid' only in my experience.
'It isn't easy having a good time .... even smiling makes my face ache'
Yo roma_turok - as I said dude - it's just a scratch guide, not for beginners - just the basics. If I get time I'll do a more in-depth one with pretty pictures etc (I'll let you know when it's done). This guide was purely to get the essential parameters to those who needed them as the tools used are quite common and have many many tutorials on their use in these forums.
Compress PAL DVDs to watch on WD TV Live Hub...
By nharikrishna in forum Video ConversionReplies: 6Last Post: 27th Apr 2012, 06:13 -
What Conversion do i Need To Watch DVDs ???
By musicmad in forum MacReplies: 4Last Post: 5th Apr 2012, 06:21 -
I want to watch PAL formatted, Region 2 DVDs in the USA.
By Lori in forum DVD & Blu-ray PlayersReplies: 18Last Post: 10th Jul 2008, 19:39 -
Want to watch rip'd DVDs by hooking up MacbookPro to TV. Some audio Q's...
By marklight in forum MacReplies: 1Last Post: 23rd Apr 2008, 18:53 -
Anyone use a Multimedia hard drive to watch DVDs/videos on their TV
By Lothar1974 in forum Media Center PC / MediaCentersReplies: 1Last Post: 25th Oct 2007, 17:37
