I have a computer with a Pioneer DVR-A04 installed in. I am using Windows 2000 with Nero 6.6.0.8a. I upgraded the computer with a Pioneer DVR-A09XLA. Now when I burn a dvd, it only works on my home dvd. I installed iso-buster, and the discs burnt with the A04, have a iso & udf folders. The discs burnt with the A09XLA do NOT have any folders of that kind. Could this be a firmware bug in the A09XLA ,a bad drive, or a problem with Nero? At this time I do NOT know what firmware revision is in the A09.
Steve
You stated that it only plays on your home dvd, what else do you want it to play on? What doesn't it play on? What media? + or - ? Download DVDInfoPro to find out media and drive details. Look your player up on the DVD Players list on the right here to find out what media is compatible with it. As far as I know, only the VIDEO_TS folder is needed, sometimes AUDIO_TS for really old players.Originally Posted by gf
I am using dvd-r disc's, Ritek & Memorex. The discs burned in the dvr-a09xl play in either Pioneer DVD burner, but not in the Lite-on dvd roms. I have a home Pioneer DV-434 and the discs play fine.
Some older ROMs may not play burned discs, the one on my laptop didn't. But that is funny, it plays on everything but your Lite-On. If it will play commercial dvd's, then maybe it just needs a firmware update. Check out - http://forum.rpc1.org/portal.php
Update to firmware 1.40
Hi Lordsmurf,
Well I wanted to get back to you on this one, you suggested to update the firmware, and it did fix the problem. I did not think that the firmware could be that screwed up in a new unit, but I guessed wrong. Now it works great, and THANKS AGAIN!!
Steve
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
