When using TMPGEnc to convert to AVI, I try to use mp3 audio. But, my options are limited. The highest bitrate it allows me is 56k/s, and the highest sample rate is 24k. why?
is there any way to fix this?
I do have lame installed, and it lets me use mp3 for MPEG-1/2, but not for avi!
asdf
Your choice of application for creating AVI is somewhat out of the main stream. VirtualDub should be a better option.
/Mats -
VOBs are just parts of a video-DVD taken out of it's context, not something you should use for anything. Use ReJig to demux video and audio out of the VOBs (you can select multiple VOBs and demux them as one) if you want some source material for further conversions/edits.
/Mats -
Probably a screwed codec installation. You have the lame dll installed correctly?
/Mats -
You need: LameACM.acm, lameACM.inf and lame_acm.xml. It's included in the latest LAME package found probably here (look under tools), and at doom9 for sure.
Place the 3 files indicated above in a directory, right-click the .inf file ans select Install. Done.
Fire up VirtualDub, and you'll see Lame MP3 as a compression option, with up to 320 kbps CBR available.
/Mats
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Problem with TMPGEnc and AVI2 (OpenDML AVI)
By Firre in forum Video ConversionReplies: 1Last Post: 24th May 2008, 12:19 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
