I have Finding nemo DVD and i wanted to make copy of it.
i used dvddecrypter and ifoedit(tp cut into 2 dvds). I tried the same with other movie and it worked fine. With this DVD i have an issue. It does not play in dvd player and even in the PC :(.
file system looks ok in both the dvds. Please help me. Let me know if you need more information.
Naveen
When you rip it with DVD Decrypter, make sure you only rip the first angle. Finding Nemo has a multi-angle structure for the visual commentary track. This might be your issue.
Read my blog here.
how to rip the first angle only ?
Actually I have already ripped the DVD (i did this long time back). Before I could burn it, the original disk has gone bad. how do I recover now ? I can not rip. But I have the ripped files. Can I do something with that ?
Naveen -
I second jtoolman2000's recomendation. Take your ripped files and use DVD Shrink 3.2. Shrink it and burn. If you have the files on your HDD, then use the Open Files option. Then click ReAuthor. Drag and drop Title 1. Backup to a new folder and then burn it. If your original files are ripped properly and intact, you should now have Nemo ready for play.
Finding sound engineers?
By takearushfan in forum Off topicReplies: 3Last Post: 27th Dec 2010, 20:04 -
PS3 not finding a file on PC
By Fizbin in forum Video Streaming DownloadingReplies: 5Last Post: 1st Oct 2010, 09:58 -
A little help finding the right ripper for me, please?
By Cygnus111 in forum DVD RippingReplies: 4Last Post: 9th May 2010, 11:27 -
Finding the balance (x264)
By doggyjumper in forum Video ConversionReplies: 27Last Post: 8th Dec 2008, 12:04 -
Help finding clip maker
By fortune in forum Off topicReplies: 0Last Post: 7th Aug 2008, 16:18
