I've been trying for weeks and days on how to convert a AVI file into a video_ts folder, but just don't know the best way to do so. Does anyone know the best way to do this? If you do, can you please provide a step-by-step process. This would be so helpful.
Thanx.
Results 1 to 9 of 9
Drop the AVI, select "DVD ffmpeg" or "DVD mpeg2enc" target format, click "Encode", wait for the "Finished" message.
To make the video widescreen you should set autosize to "DVD 16:9" immediately before encoding. About the missing VIDEO_TS, you should make sure you don't use the same filename as the previous encode. You may reauthor the MPG file into a VIDEO_TS folder by loading the MPG in "Tools", enabling "Author as DVD" and clicking "Author".
To author as DVD, proceed as follows.
1. Click the "Tools" tab
2. Click the first "browse.." field. It will ask you to select a file. Select the MPG file.
3. In the left area of the "Tools" tab there is a checkbox named "Author as DVD". Enable it.
4. In the right area of the "Tools" tab there is a button named "Author". Click it.
5. Done
Is the VIDEO_TS folder supposed having the .VOB file?
By coody in forum DVD RippingReplies: 6Last Post: 19th Dec 2011, 01:38 -
Convert VIDEO_TS folder into a SINGLE AVI file
By donkeyking in forum Newbie / General discussionsReplies: 6Last Post: 29th Apr 2010, 15:32 -
VIDEO_TS folder to single sized file possible?
By THX-UltraII in forum Video ConversionReplies: 3Last Post: 5th Feb 2009, 01:32 -
Converting a Video_TS folder into AVI
By HankE in forum ffmpegX general discussionReplies: 11Last Post: 6th Jan 2009, 14:48 -
Is it better to burn a VIDEO_TS folder or a MPG file?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2007, 16:54
