I find animated avatars and animations in sigs annoying. Is there a way to disable these? If there isn't, there should be an option. In other forums I can turn it off/on, but I don't see it as an option here.
Closed Thread
Results 1 to 25 of 25
There's a PHP mod to allow it - The Pub has it.
If in doubt, Google it.
but but... how can you deny them the glory of our avatars and banners?
edit: maybe this http://www.phpbb.com/phpBB/viewtopic.php?t=141622
Added!
stryler: check under your Profile, for show avatar and signature.
Use an ad blocker and block everything at:
https://www.videohelp.com/forum/images/avatars/
Originally Posted by mikesbytes
Regards.Michael Tam
w: Morsels of Evidence
I tried without sigs and avatars and it didn't feel right.
I put back the avatars and I like that much better.
At least now I don't have to go bug eyed trying to swat that stupid spider running across the screen
Love it!!
Thanks stryker for suggesting it and Baldrick too for following through on the idea.
Originally Posted by 44echo
That would be BJ_M
It freaked me out at first but I'm used to it now
I tried to change my 'member status' today, and it just reset to 'member' and refuses to change to anything else.
Also part of my sig disappeared, though it shows it's there in my profile.
I also changed some computer details, would this have triggered the problem?
I can't figure out what happened.
EDIT: wierd. Now my sig is back, but the member status hasn't changed.
2nd EDIT: Tried several times, now it suddenly works. I have no idea why.Ethernet (n): something used to catch the etherbunny
We've got three guys from Australia using the same background. I couldn't find anything much that suited me...
Originally Posted by Cobra
BTW, nice job on the pic, Cobra. Looks a lot like youIf in doubt, Google it.
I cant find hide files in my DVD
By GOH in forum DVD RippingReplies: 1Last Post: 20th May 2011, 23:33 -
Can i hide a file/folder on a cd/dvd?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2010, 09:14 -
hide moving object in VDub??
By 3thman in forum EditingReplies: 2Last Post: 16th Oct 2009, 08:53 -
How does one create/find graphic and motion avatars?
By PosRole in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2009, 07:32 -
First posts to end all first posts
By zoobie in forum Off topicReplies: 4Last Post: 24th Apr 2009, 12:54
