I picked up a copy of ReelDVD off ebay and got it yesterday. I attached this dongle to my parallel port (port enabled), and soon wound up with a corrupted boot.ini file and some nasty comment about NTOSKRNL (or something to that effect). It seems my computer did not take well to having a dongle stuck in its parallel port (come to think of it, neither would I but that isn't the point). Has anyone else experienced dongle issues?
Have you changed your Windows Boot logo?
(The logo is in file NTOSKRNL.EXE)
Perhaps it objects to having a non-standard NTOSKRNL file. -
dont use the drivers on the cd , use the latest drivers for it off the main web site (the dongle drivers)
This isn't the place for discussing dongles!
: ) jjGoogle is your Friend -
Thanks guys. I ended up reloading my O/S. It needed it anyway. Most of my data was on the other drives anyway. Seems to be OK now, I'll check out new drivers too. Yeah, who named that thing a "dongle?"
Since you asked:Originally Posted by fmctm1sw
http://en.wikipedia.org/wiki/Dongle
The word dongle has been used as a placeholder name (akin to doodad or whatchamacallit) since the 1970s. Its origin is unknown. The American Heritage Dictionary, 4th edition, says it is "probably [an] arbitrary coinage." Claims that it was derived from the name "Don Gall" are an urban myth popularized by a 1992 advertisement for Rainbow Technologies, a dongle vendor.
Dongle as the name of a device was used well before 1980 within the telecoms industry to refer to BNC cable joiners of either sex (such as the RG58 cable used on 10 meg Ethernet).
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
WiFi dongle compatible with Philips BDP3200
By xodeus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jan 2012, 23:14 -
3 dongle problem
By Mr anderson in forum ComputerReplies: 2Last Post: 6th Feb 2011, 09:43 -
Wifi to Ethernet dongle?
By rhegedus in forum ComputerReplies: 5Last Post: 24th May 2009, 01:53 -
carbon coder usb dongle error
By sid_dionne in forum Video ConversionReplies: 9Last Post: 9th Apr 2009, 14:27 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19
