When the VideoCD (NTSC).mcf template is loaded, in the settings at the Advance Tab there's the Source Aspect Ratio:
4:3 525 line (NTSC)
4:3 525 line (NTSC, 704x480)
My question is:
What is the difference because I tried both and both works on my Pioneer DVD player?
Any help is appreciated.
4:3 525 line (NTSC) normal use with DVD source because of resolution 720x480
4:3 525 line (NTSC 704x480) I'm not sure what source to use with but if I create menu I always use this resolution (704x480) for my picture. -
I was curious too, so I did a little 10-second test clip and tried both settings (on CDRW), and found that the 704x480 setting cuts off just a little of the screen, at least on my Apex player. It's hardly noticable unless you look for it, but it's there. So I always use the 'regular' setting.
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 04:17 -
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 09:35 -
Aspect Ratio Question + Some
By Alexander4444 in forum Video ConversionReplies: 7Last Post: 9th May 2011, 02:17 -
Aspect ratio question
By gallootjs in forum MacReplies: 4Last Post: 10th Mar 2008, 02:14 -
Aspect Ratio Question (Sorry!)
By rede in forum Newbie / General discussionsReplies: 12Last Post: 30th Dec 2007, 07:25
