What is the best way to go from a DIVX (AVI) to SVCD? I would like to be able to use CCE to encode, but will take other suggestions. Thanks.
Going to SVCD to divx often results in a noisy svcd. VCD is probably better. Try tmpgenc 12a if you want to though
I've never had a single problem converting Divx to SVCD,
NTSC or PAL. I've used several versions of TMPEGnc, most
recently 12h i think is the latest.
But oddly, however, i've had tons of problems converting
Divx to VCD! So i went directly to SVCD instead of fighting
along with VCD specs. I've burned many Divx->SVCD's to
90min CDR's quite nicely.
Give it a try.
<font size=-1>[ This Message was edited by: Cosmo Kramer on 2001-07-16 09:35:16 ]</font> -
Keep in mind that DivX has less information of the movie than with SVCD (SVCD takes 2 CD's and DivX mostly only 1).
So converting to SVCD will result in less quality... -
And also it depends what kind of material you're encoding
(Divx->SVCD). Slow motion film material you can use lower
bitrates that gives you more space in CDR-wise.
CK.
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
