Results 1 to 11 of 11
  1. Hi Guys,
    I picked up a Phillips something or other DVD player the other day and just noticed that it is DIVX 3.11 enabled. Neat!
    If I get this straight... I would burn DIVX AVIs, as many as I can fit on a regular ol' DVD-R, as a Data DVD? I assume that when I pop in that DVD the player will present a menu of the AVIs asking which one I want to play? Does it just like... work... ? Sounds to good to be true. :]
    1) what about AVIs labelled XVID? Not gonna work?
    2) would a DVD-RW work just the same? ie: burn & have 3 or 4 AVIs, re-burn and 3 or 4 different ones... don't see why not right? ;]
    This would save me a headache of encoding AVI to MPEG2 and compressing and burning and what not...
    Thanks for any info guys,
    - Martin W
  2. only_emo_kid
    Guest
    yes! i've got it also, and its awesome!! thats all you hafta do is burn .avi to dvdrs or whichever media you want.
    Dec 2003
    Eugene, Oregon
    Double-check the Philips manual. I recently checked into this with some kind of DVD player and the Divx movies had to be burned to CDs, not DVDs, to play.
  4. only_emo_kid
    Guest
    i've burned a bunch of random stuff I just wanted to watch on tv to dvd-rw and it played fine... divx .avi's to dvd played fine for me...
  5. Same here, Xvid,Divx,Mpg2,Mpg1,
  6. That's probably the coolest thing EVER. :]
    Thanks guys!
    - MW
  7. How does it work if the files are widescreen? Does the player automatically add the black bars?
    Jun 2001
    Silver Spring, MD USA
    Actually it doesnt add black bars, it just fills as much of the tv screen as possible without distorting the image.
    On a widescreen tv you have to set the tv's display mode appropriately.
    As a Mac user, I find it best to encode to the highest resolution the player can take (for NTSC, 720x480) and then using my tv's display mode to stretch 16:9 content to the correct aspect. It makes great quality encodes but the bitrate is sometimes too high for CD burns (chokes on playback from CD but plays smoothly from DVD).
    I noticed on a couple of old DivX movies from my PC days, the fast-forward and fast-rewind didnt work, but with my Mac encodes they always work. I think this comes from having used an extremely large number of frames between I-frames (more than 300).
  9. Oh, it squishes a widescreen to 4:3? That's baaad...
    Jun 2001
    Thats not what I wrote.
  11. I just played around with my DVD player by burning some widescreen and fullscreen AVIs to Verbatim DVD-R... :] :] Very pleased, they all played in the correct aspect ratio and pause/fastforward/etc... etc... all worked GREAT. :]
    I have a question though... my DVD player doesn't really present a menu, each DIVX is a chapter like you hit next to get the next one...
    Is there a program that I can use to make a cool little menu at the start of the DVD w/ the movie titles and the order that they are in?
    OH AND - should I be burning my data CDs w/ any of the special options in toast? I've been making them as "Mac & PC" but there is also DVD-ROM UDF, ISO 9660, Mac Only etc...
    Very cool,
    - Martin W
