I have downloaded the above proggy which is demo version. I have created a effect(finally) need to export it to an proggy in which i can use this as text whcih falls away like sand. I need to add back ground video and use it in a project. At the moment the text fall to the ground but the background is black. If you know which proggy to export to and how I can achieve this in detail please set it out for me
thanks
export it to a Proggy? I think if you save as AVI with alfa channel you will beable to use it as an overlay on your Video.
Tell me what you have now/ -
I would like to export it but can you show me how, coz the only export option in the menu seems to be targa file?
thanks -
Here take a look at this page.
http://www.borisfx.com/timscorner/ppt.php -
Hmm I only had the export pict option, its prob the demo. Anyway downloaded the red demo. Now it had the movie file option. I tried using directshow and the other but both gave me errors even using uncompressed setting. Then exported it as quicktime file and then reencoded it wiith tmpg, finally got something to work. By the way could any of you tell me why I get errors while using normal export video files.
thanks
How may I access to Boris RED 5 in SONY VEGAS 11?
By daniel827 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2012, 22:39 -
Boris Continuum VS. AE
By budwzr in forum EditingReplies: 17Last Post: 16th Jun 2011, 16:32 -
Pinnacle 12 and Boris
By romanticwarrior in forum Authoring (DVD)Replies: 0Last Post: 15th Jul 2008, 11:43 -
Boris Fx and Sony Vegas Pro 8
By mashimiriam in forum EditingReplies: 5Last Post: 27th May 2008, 22:27 -
boris FX plugins make premiere pro heavy performance
By yunakokimama in forum EditingReplies: 5Last Post: 3rd Mar 2008, 18:12
