Hi...this is me caesar...
I'm having an annoying problem with DVD-Lab Pro
I'm trying to put an mpg file that I've made with Power Director putting my name in it...then I put it ((OF COURSE I ONLY PUT THE .MPV FILE WITH NO AUDIO)) in the same VTS with the original VOB file
that I have but I've got some audio sync problems that the audio began after about 2 seconds...
so I've tried the ( audio delay ) option In DVD-Lab Pro and it didn't work
Then I've noticed that each time I recomiled the project some
VTS files have the problem and the others don't although they contain the same thing...I've tried to recompile again and again and each time I've
got one or two different VTS files with audio synchoration problems...
and I've tried to put the mpg files that I've made in a different VTS
and made a play list for them to be played before the VOB play..
and I've got the same problem....
((NOTE: I USE DVD-Lab Pro AND DVD Maestro AND MY PROJECT CONTAINS DD AUDIO AND DTS AUDIO))
SO PLEASE ANY GOOD IDEAS WILL BE GREATLY APPRECIATED
FOR MY HEAD IS GONNA EXPLODE [40 compiling in 2 days and nothing in advance]![]()
CAEASR
In what way does audio delay not work ?
If this is happening seemingly at random, and in difference parts of the structure during different compiles, then I'd suggest starting with an uninstall/reinstall of DVD Lab Pro, then I would patch DLP up to the latest version. Then I would demux all VOBs and work purely with video and audio files.
Then I'd ask myself - if I have Maestro, why am I using DVD Lab Pro ?Read my blog here.
Well I know it seems funny...
but I hate DVD Maestro and wouldn't pay
one dollar for it if I knew how dumb it is....
It keeps annoying me with massages about missing filters espicially for DTS audio which is soooooo important in all my projects...and I discovered that Maestro doesn't support it at all ((or to say:it supports it just a little bit))...
I don't know what's happening with my dumb DVD Maestro but I know that I've tried to install all the filters that Maestro asked me for..and it's still the same old story....(( the required filter is not installed on your machine)) that's what Maestro allways telling me..
ANY GOOD IDEAS ABOUT WHAT HAPPENING WITH ME IN DVD-Lab Pro OR DVD Maestro WILL BE GREATLY APPRECIATED...
THANKS FOR HELP
CAESAR -
Read this thread:
https://www.videohelp.com/forum/viewtopic.php?t=262335Cheers, Jim
My DVDLab Guides
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 02:11 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 01:12 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 16:05 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 04:46
