Hi
I have ripped a DVD with DVD decryptor. I'd like know to re-author it with DVDshrink, but it doesn't recognise the files. Anyone knows what to do.
thanks
What error do you get with DVDShrink ?
What DVD are you trying to backup ?
It should just be a case of ripping all the files on the DVD to your hard drive as files or as an ISO file.
It also might pay to read this thread, as you may have a DVD that has the Arccos copy protection (or whatever it's called).If in doubt, Google it. -
Did you have dvdshrink create VIDEO and AUDIO_TS folders. If so dont .
I had a problem when it created the folders and it wouldnt play either.
Create a VIDEO_TS folder on your desktop and browse to put everything in there. If you use Nero which I no longer use unless to play the movie on PS2 it will have the folders already. GOOD LUCK
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 10:22 -
Author 5.1 DVD
By Astrogirl in forum Authoring (DVD)Replies: 4Last Post: 7th Apr 2008, 15:43
