I have looked at several guides on this topic, and tried downloading and using VirtualDub MP3 Freeze, but when I attempt a Direct Stream Copy and appending my two AVI files, I get the following error:
The audio streams have different data formats
Does this mean I have to full reprocess, or something else? Any help at all would be greatly appreciated.
Try to use AVIMUXGUI. When I get that error in virtualdub I always use this program and does a great job!
..thoughts arrive like butterflies.. -
or convert the audio to same format. audio->full processing and audio->compression in virtualdub.
If your ultimate goal is to convert the joined AVI to MPEG for making either a VCD or DVD with then proceed as follows:
Demux the audio out of both avis with whatever method you most prefer. I like Goldwave myself but VirtualDub will do it for you as well or a multitude of other applications;
Join the audio streams together with WavCat or similar;
Convert the two avis separately with your encoder/settings of choice;
Join the resulting MPEGs together with Womble MPEG-VCR;
Remux the audio back together with the MPEG elementary stream you got from Womble.
Voila, you now have a perfectly joined MPEG for burning to disc with no join noise in the audio stream at the cut.
I have in the past joined the first half of a movie in NTSC encoded with DivX v3 and with MP3 sound to the second half from a PAL source encoded with XviD and AC3 sound using this method. It joined perfectly and you could not tell where the cut was in the end result. You might have to play with the audio levels a bit as well to maintain a seemless sound level at the cut.
It helps if you have an overlap of video at the cut as well of course. Luckily I did. -
Don't join at all. Just encode each AVI to DVD mpg specs, author as 2 parts of the same title.Originally Posted by DRP
/Mats -
On my DVD player at least that results in a very slight pause during playback as it shifts from one title to the next.Originally Posted by mats.hogberg
Yes, others have reported that too, even if I can't say I've noticed any pause. The rumored cure is to remove the chapter point TDA by default sets at the join.Originally Posted by DRP
Either way, I prefer a slight pause to the work and problems that joining the source material involves.
/Mats
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 9th May 2010, 00:16 -
Export DV AVIs without re-encoding in Premiere?
By moxiecat in forum EditingReplies: 1Last Post: 2nd Aug 2009, 04:04 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 22:14 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 15:32 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 10:30
. It's appreciated more than I can say!
