I can't run any dvd's that I make using dvd-shrink on my computer. they all run in my standard player that is hooked up to my t.v, but it doesn't even show up as files on my comp. do i need some patch or something to get them to work? I think it might be because they are on dvd-r's and that my dvd player on my comp is old so i need some patch. anyone know more about this?![]()
They must play with your DVD writer which you used to burn them? Right?
What brand and model of DVD ROM do you have? -
What software DVD player do you have installed ? Windows media player will not play DVDs out of the box.
Read my blog here.
if it is coming from the same drive as the one that you burned it on then it shouldn't be a problem. Check to see your not trying to play a dvd using a cd drive.....you cant imgaine how many ppl try that
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
