  1. Hello,
    I am using Vob2audio in order to get better sound for my Dvd rips. I seem to be having a problem with the program. I did get it to work once but only after about 10 minutes and it seemed to start working on it's own. It opens up fine and when I load the vob file, the little dos windows pops up but it closes very fast all by itself. The I see my audio choices to pick my audio stream from. It also lets me choose a target file. No problem with any of that. But it seems that the start-stop-quit buttons at the bottom do not work, although the program is not locked up. The only time I did get it to work, I loaded the vob, picked the audio stream and the target file and after about 10 minutes, it just started by itself. It wont do that anymore. If I can't resolve this problem, is there a different program that I can use? The project I am doing is using the Pinnoy guide for 5 speaker sound. Thanks to all.
    Catman
  2. Catman try to uninstall it and reinsatll it....if that doesnt work for you try GraphEdit but it is very hard to setup
  3. Thanks Pinnoy. I reinstalled it but with no luck. Someone else must be having the same problem so maybe they will respond. I am going to try the other program and see how it goes. Thanks again.
    Catman
  4. Catman the other program is to hard to setup you have to put the filters yourself and that not has good for a newbie..this is why i picked vob2audio to rip the audio beacuase it setsup everything for you
  5. one last quaestion where did you download your Vob2Audio???? if you downloaded it off some other site ...try http://www.doom9.net to download Vob2audio he has to have the latest one becuase he updates his software list everyday ..soo try there
  6. I solved the problem with Vob2audio. I believe that the problem is a problem with WinXp. When the program opens up it does not fill up the whole window that it opens up into. There is a gap at the bottom of about 3 inches wide that it does not fill up. You can click on the start and quit buttons all you want but they wont work, but if you click about 2 inches under the start button in the white area, the program begins to encode and all is fine. No more problems, I just had to keep trying things to get it to work. Dr. Evil who wrote the program says its a problem with Xp. So I hope this helps but all is fine. Tomorrow I am getting 5 speaker system!! Take care good friend.
    Catman
