Will a stand alone digital DVD recorder capture video from a VCR playing old analogue VHS tapes, without having anything else such as software, video capture device, and if so,would you just hook VCR and DVD recorder together with RCA A/V cable,(yellow,orange, white) on both ends?
Next question- Can you then copy the disc you just made from the VHS tape to your computer by inserting it in the DVD or CD drive on your computer??
As you can tell by this post, I am about the dumbest person around when it comes to electronics. I would though, appreciate any help.
newbie john
I just bought the Pioneer 220-S DVD recorder. I've copied some analog VHS tapes to DVD with no problems.
I use a cheap $60.00 SONY VHS. You can insert the disc burned from the dvd recorder but it has to be recorded in the VIDEO MODE and the disc has to be finalized. The VIDEO MODE will enable the disc to be in compatible in standalone dvd players. Remember to finalize the disc.
Computer video capture vs. vcr to dvd combo?
By Haopengyou in forum Capturing and VCRReplies: 24Last Post: 18th Dec 2015, 23:50 -
Video slowdown on DVD-Rs. What's to blame? VCR or DVD Recorder?
By ministry88 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 10th Feb 2009, 19:03 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 13:53 -
Composite of S-Video from VCR to DVD Recorder ?
By cd090580 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 27th Mar 2008, 20:53
