I only have OSX 10.2--any way to manually simulate the PSP pre-set on an earlier version of ffmpegx? Thanks.
Versions after k require OSX 10.3
http://homepage.mac.com/major4/psp.html
On this page major mentions psp uses a specific header so I'm guessing that although it might be possible to get the same encoding parameters with version k, there's a chance the video would not play if the older ffmpegx has not set the mpeg header properly: there is a specific psp profile listed in the options tab.
Alph
PSP encoding woes - chipmunks overruning the audio
By Cyntalan in forum Video ConversionReplies: 0Last Post: 27th Jan 2011, 21:48 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 03:42 -
Encoding for the PSP
By Suzuka in forum ffmpegX general discussionReplies: 2Last Post: 30th Sep 2008, 16:01 -
PSP encoding error
By richgone in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2008, 08:06 -
Method for encoding Motion JPEG for PSP
By ByteMe72 in forum ffmpegX general discussionReplies: 6Last Post: 13th Nov 2007, 18:02
