I have had a few movies that were eather mpg or avi and converted when necessary and tried to burn them to dvd and all I get is a short part of the movie burned to dvd.can anybody tell me how to fix this or what the problem is
Closed Thread
What the heck are you talking about. Use complete sentences, describing step by step what it is you are trying to do. Then you will recieve help very quickly.
Source of movie file
Original format of this movie file
What programs you used to convert to MPG2 - don't use abreviations
What programs you used to author the MPG2 files to DVD
What programs you used to burn the resulting DVD files or ISO to DVD
What meda
What burner
In fact, every thing that pertains to that project in detail.
If you don't do that we are going to spend a lot of time going back and forth asking for pertinent details you left out.No DVD can withstand the power of DVDShrink along with AnyDVD!
I got the movie from ---- it is -----
it is in mpg format
I am using roxio dvd builder 6 to author and to burn
I am using a tdkdvdrw040n dvd burner
and when I am finished it only gives the first few minutes of the dvd which has happened to me once before while trying to burn bambi in the same way and the same programs
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Flaystus
Buy the originals and then back them up using the guides published here ot elsewhere. Discussion of downloaded videos is very much frowned upon here. You should try rephrasing your previous post with actually giving the name of the movies if you don't was abuse rained down upon you.
Read my blog here.
You say you can view the mpeg file on your computer then it is possible that the Roxio DVD Builder on your system is not authoring the mpeg files properly.
Try to use TMPGEnc DVD Author or DVDLab Pro or any other to author your files.When I was born I was so shocked that I could'nt speak for 18 months.
Burning movies with subtitles?
By legenderycity in forum Authoring (DVD)Replies: 10Last Post: 2nd Apr 2014, 02:25 -
back to burning movies
By ford10000 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2009, 02:38 -
help burning movies?
By pbure0110 in forum DVD RippingReplies: 3Last Post: 31st Dec 2007, 02:43 -
Help new to burning movies
By SkunkMan in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 09:56 -
burning 3 movies in a DVD
By hackerzlab in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2007, 17:32
