    Lisbon
    Hi i´m having a big problem trying to conver Divx to DVD.I´m using Nero Vision Express and i only made one DVD.
    The problem is that my PC freezes or shots down while i´m tryin to convert.I don´t now why.Can some one help me??
    What should i do???
    I have an Pentium4-2.00Ghz and 702Md Ram.
  2. Member wulf109's Avatar
    Jul 2002
    Try VSOdivx to DVD,it's freeware and works well. I converted several DIVX videos to DVD with it. Worked perfectly and even converted the audio to AC3.
    Lisbon
    Tanks man i´ll try it.
    With this program can i work on several things or just let it work alone.
    Peace and Love
    Apr 2004
    Miskatonic U
    Any encoding requires a fair bit of CPU. If you try to do other things, you will slow the encoding down - that is, if you can do other things. Most encoders will swamp the CPU, and you'll be lucky to get anything else happening.
    Read my blog here.
    Lisbon
    Ok i hope that my pc stop crashing :P
  6. Originally Posted by guns1inger
    Bring up Task Manager and lower the priority of your encoding program.
    Lisbon
    Does this program load automatic the subtitles,or i have to use other program befora i burn it to an DVD.
    Tanks
