    May 2003
    sheffield england
    i am a newbie can anyone help please
    i have copied 2 dvds 4.7 g into nero then i created a 8.2 g file with image file the image file plays perfectly in the mounted image i.e both dvds follow each other but when this is burned onto a dual layer dvd+r the who image burns onto the dvd but when it comes to play it only playes the first dvd then crashes when it tries to start the second one
    am i doing something wrong can anyone help with a guide or point me in the right direction
    please help joe
  2. It sounds to me like you are going to have to do some reauthoring. You will probably have to design a menu that has links to the two movies.
    On the other hand, if you had in mind one continuos movie with no break in between, then you will probably still need to reauthor and set them to play back to back.
    I believe currently your disk is loading up and it's reading the IFO from one of the two features. This IFO file would only have information on one of the movies, so it wouldn't lead to continuous play to the next one.
    To get it to play continously, you're going to need an IFO file that tells it to do that. Someone let me know if I'm wrong but I don't believe there is a way to do that without reauthoring.
  3. you could also join them in dvd2one,then burn using copytodvd,it would give you 2 titles,and should work with little or no problems,nero sucks,only thing its good for it copying cds.
    LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
    May 2003
    sheffield england
    many thanks to you all
    May 2003
    sheffield england
    can anyone help me with a guide to join 2 4.7 dvds
    into one and then burn to a dual layer 8.5 g
    thanks
