I have a D-8 camcorder and am rather disappointed with my less than quality results converting to a DVD, thus far. I've been using MovieMaker to capture and edit, then MyDVD to burn. As you get what you pay for, I've paid nothing. Thus, my NEW thought process to limit my $$ output but get decent quality:
1. Capture with V-dub, then
2. Convert with TMPGenc
If I do this, what type program to edit, as all I'm looking to do is add some titles, trim files, maybe add picture files--all nothing fancy and steps I've been able to do. What type program would be good? It seems the new Vegas MovieStudio looks good.
Finally, can I import my wmv files into TMPGenc?
JT
WMV sucks for capture format.
If you want to use WMM to capture, use DV-AVI instead.
If you like virtualdub, try virtualVCR instead.
Capture using a good codec such as huffyuv, or slightly less quality with picvideo mjpeg.
Convert (encode) with tmpgenc if you must.
Vegas movie studio 4 is GREAT for editing.Cheers, Jim
My DVDLab Guides -
Thanks, Jim.
Another question--for encoding to the DVD format...
..Why not EXPORT your edited file BACK to the DV Camcorder, then send the movie to a DVD Recorder via the firewire port. Would that not do essentially the same thing, but result in a better end product?JT -
/Mats -
That might be so, but when was "QUICKER" == "a better end product" ?
/Mats -
Forget all that and try the new Sony direct to DVD DISC recorder/burner.
Just plug in your camcorder, etc. and record away.
Easy as it gets
Here's the link
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1126084&CatId=4
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 20:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
