  1. but do see it is all there on my standalone player when I fastforward it..........
    It sticks on the first second of the disc and will not move nay further yet it is all there when i fastforward it...what is the problem here and how can I solve this.I have had this once b4...I burned it with cdrwin as it was a bin/cue file.......
    tia.
  2. Tia,
    Don't really know what the problem is nor am I familiar with bin/cue. Could you switch to TMPGEnc. to encode it into SVCD and the burn it with Nero? That's how I made my XSVCD and it works fine. All softwares are free, so might want to consider it? Jordan
  3. it already comes as a svcd after burning the bin/cue file.........I had this with a recent rip of Godfather part 1 as well........
    Anyone else?
  4. Did you encode as a compliant svcd or is it an xsvcd? Does your player support the bitrate you used? Maybe you should try authoring in VCDEasy or TSCV instead of Cdrwin. If that don't work you could try demuxing and remuxing the mpeg file in TMPGEnc. Possibly also try running the video through Mpeg Sequence Maker before remuxing the file.
