I have two movies in separate video_ts folders, each containing a menu and ready to be burned. However, by their small size, they both fit on one dvdr. I want to put them both on one disc, adding a menu that will let me choose either one of them upon the insertion of the disc, maintaining the original menus and structure present on both of these movies.
I'm a total newbie to dvd authoring, so preferably I am looking for a program that will do most of the work for me, and/or a good guide on how to proceed.
Thanks in advance for your help.
tmpgenc dvd author, select add dvd video and select the video_ts folder. add both folders. done.
DVD LabPro will allow you to "Attach External VTS" (complete with menus).
DVDRemakePro (from dimadsoft) will also let you combine two DVD Videos into one DVD.George -
if you want to maintain the original menu you can't use tmpgenc dvd author...(missed it)...use dvdremake pro then as georgew says...click on it for guides.
A vote for DVDRemake Pro here. Does this job very nicely indeed.
If in doubt, Google it.
Playing AVI Movies as data files with menus
By shans in forum Authoring (DVD)Replies: 25Last Post: 10th Mar 2011, 10:43 -
write 2 movies in 1 disc
By akakiami in forum DVD RippingReplies: 6Last Post: 10th Sep 2008, 08:06 -
Looking for a simple program to redo dvd menus for my home movies
By brycej817 in forum Authoring (DVD)Replies: 2Last Post: 24th Jan 2008, 15:31 -
Two movies on a 4.7MB disc??
By Noy2014 in forum Authoring (DVD)Replies: 5Last Post: 15th Aug 2007, 12:08 -
Best program to create a DVD with menus for home movies???
By orbital517 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 22:14
