what progam can I use to extract audio file from VOB ?
You can use the MPEG Tools in TMPEGEncoder. There is a demux option that will allow you to rip out just the audio stream (regardless of whether it's AC3 or MP2).
Well...It depends on what format do you want the audio file to be...
if you want .ac3 ((DD audio)) or .dts ((DTS audio)) that are
the usual audio formats available in .VOB files you can use
DVD Decrypter in the Ifo Mode and you'll be able to select which audio stream to extract......
CAESAR -
DVD Audio Extractor will will extract any audio format a VOB has to offer and save it in its original format. Also, it's lightning fast.
Chas
Extract frame from VOB file.
By kwazi in forum ProgrammingReplies: 8Last Post: 17th May 2013, 17:24 -
How to extract audio from .vob files
By webadm in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2012, 21:28 -
extract subtitles from .VOB file
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2010, 12:19 -
Extract subtitles from VOB files
By webstar in forum MacReplies: 9Last Post: 29th May 2009, 15:34 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 04:56
