Not sure if you can mix 'em - try it out and see... Someone else may be able to confirm if you can or not.
Good luck...
Results 61 to 76 of 76
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
can i test burn onto a VCD instead, using the m2v..., and check it that way??
Wow! You got shocks, pegs... LUCKY! -
Possibly - You'll need to have the DVD folder format (VIDEO_TS and AUDIO_TS) on the CD.
Some players don't play what are called miniDVD's.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
no i mean like can i use VCDEasy and encode the m2v to and mpeg-1 and burn on CD and play in my DVD player (VCD compatible), and will it be safe to assume that whatever the result is, it will be the same when i play my finished DVD in my DVD player?
That means the m2v (MPEG2) will become an m1v (MPEG1). Yes, I don't see why that wouldn't be a valid test - the resolution will be lower, but that doesn't affect the "shape" (i.e. 4:3 or 16:9) of the footage.
Well, as far as I know anyway...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
ok cool, im gonna try ill let u know the outcome
In tmpgenc, Advanced tab, set source aspect to 1:1 vga. Below that, set Keep Aspect Ratio 2.
It may look squished, but it won't on the TV.
Use a DVDRW to test.Cheers, Jim
My DVDLab Guides -
ok lemme tell u exactly wat i did:
1. i encoded the AVI (with the rez - 352x480, and lowered bitrate) and outputed as an MPG-2
2. then using nero, i burned the MPG-2 to VCD
the result was that the movie came out exaclty as the rez, all squished. now im pretty sure i did something wrong, i dont know where but somewhere. so anyway please tell me how to correct this, and another question
can i just make the rez smaller (keeping aspect ratio) and lower the bitrate and out put that as an m2v?Wow! You got shocks, pegs... LUCKY! -
wait a sec so i shouldnt make rez 352x480, jus do the full screen Keep Aspect Ratio 2, plus the reason why im using CDs is because i dont have any DVDRWs
plus im gonna like burn a lot of disks to get this rite, do u know which program makes a multisession VCD
You're starting to lose me here...
If you want to test something, it's always best to test it in a situation as to how it will be used. So, ideally, to get trustworthy results you need to be burning MPEG2 files (m2v) authored as DVDs at the resolution and bitrate you want.
Burning to CDs coz you don't have DVDs detracts from this. Take time out to go and get yourself a DVD-/+RW. They're not expensive.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
ok thanks, today was an off day, ill take ur advice, thanks ....
We all have 'em...
While you're out shopping, you might wanna get a CD-RW too - if you think you'll need one.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
yeah smart, i might go tomorrow, in the mean time im gonna do some....EXPERIMENTING....mwahaha..:P
Originally Posted by skip2mylou
Are you going to make VCD, SVCD or DVD from these files?
I need to know which before I can suggest anything.
You cannot reduce the res to a half D1 aspect, then burn it as an (S)VCD.
Are you trying to burn these to CDR just to test? It won't work. Buy a DVDRW to test, and encode properly and burn properly to begin with.
If you're going to burn a VCD to test, then encode to 352x240 m1v and burn a VCD. Waste of a disk, as it's not going to tell you anything about the finished quality when encoded to half D1 mpeg-2 on DVD, or even 480x480 SVCD.Cheers, Jim
My DVDLab Guides -
ok i see wat u mean, yeah i am going to make a DVD, and im gonna go get a DVD+RW disk soon to test...
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
dvd menus... are they normally 16:9 or 4:3?
By extent in forum Newbie / General discussionsReplies: 12Last Post: 18th Dec 2009, 21:06 -
DVD Menus
By matthewjohn23 in forum Newbie / General discussionsReplies: 10Last Post: 4th Apr 2008, 16:53 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07 -
4:3 and 16:9 menus on the same dvd, possible?
By Idofex in forum Authoring (DVD)Replies: 9Last Post: 24th May 2007, 19:49
