I've bought a LG dv-8700h and it plays most of my divx files perfectly but with some files it plays them very shocky and the sound will go out of sync.
I believe that it can't play files properly with a video data rate higher then 125 kbps.
Is there something I can do about this?
There is no firmware out there for LG as far as I know, so it would be great if anyone had a solution.
Actually I don't know if it's the Video data rate. just forget i said that.
it's playing shocky and out of sync. any solutions for that?
thanks -
Seems this is a flaw of all DivX players out there, noticed moreso on files with VBR audio.
Not much you can do, you could try reencoding the file with CBR, or just live with it. I've gotten more or less used to this problem with my LVD-2002. As long as it's not over a second out of sync it doesn't bother me too much.
That, plus I'm lazy to reencode...Ethernet (n): something used to catch the etherbunny
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
