I have a problem with the audio of one my movies which is very weak . I was wondering if there is a way to improve the sound quality.
Here are the info about the audio I got from virtualdub:
SAmpling rate:48000
Channles: 5 (stereo)
Compression: Unknown
Layout: 29 Chunks
Data rate: 448 kbps
Thanks in advance
Well what exactly do you mean with ((very weak))Originally Posted by mach
if you mean the volume then Sony Sound Forge is the best way to increase the volume as I've experienced...
but if you mean the quality itself ...I don't think there's a way to improve it more than a little bit...because it's something related with the source of the audio and not with your movie's audio itself....
but the info's you've written are quite good (((((448 Kbps)))))
but are you sure that it's ((((5 channels stereo)))) may be there's something wrong...
CAEASR -
The info I wrote above I have taken them from virtualdub, and they are absolutely correct. Thats why I dont understand with these settings the sound is too weak. I am not sure whether the quality of the sound is good as i can barely hear it from the speakers of my laptop.
I give it a try using Sound Forge to see if I can get a better quality out of it. -
I did exactly as sanjayk said with a tv cap but mine was 2 channel stereo. I had accidently set the volume too low and used goldwave to extract it from the avi. I boosted it 200% twice and then applied the denoise filter in goldwave to get rid of hiss that was introduced during the boost. This part was a bit trial and error but the final result was excellent.
I used vdubmod to remux the audio. I deleted the extra audio channel in vdubmod after the fact time because the file played fine in media player classic with an extra audio channel but ms media player choked on it. You could probably do this at the same time as the remux and audio compress. -
Sometimes just normalizing audio is enough. But Soundforge is very cool. Has anyone used 8 yet? Does it open AC3 files now?
How Can I Improve my video quality
By legend10 in forum Newbie / General discussionsReplies: 36Last Post: 23rd Feb 2012, 15:01 -
How would you improve the quality of this video?
By choobies in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2011, 13:24 -
What can I do to improve my quality?
By Captain Satellite in forum RestorationReplies: 12Last Post: 27th May 2009, 12:06 -
How to improve picture quality
By MI6 in forum Video ConversionReplies: 2Last Post: 25th Feb 2009, 17:37 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
