Hi...I'm Caesar again...
Does any body know how to join avi files in one avi file with the same source quality....
I've tried Cyberlink PowerDirector but it reduced the quality quite a lot although I chose the best settings and got a very big sized dvd file...
so please tell me what I have to do?????and what program do you advise me to use?????
THANKS A LOT....
CAESAR
Use VirtualDubMod.
When I was born I was so shocked that I could'nt speak for 18 months. -
Well I used it before and it caused me a problem when I tried to save
my work as .avi file...
the problem was in the size that I got....((( I filtered about 10 minutes
with my custom mark >>>>and I got about 7gigabyte AVI file
in addition (((windows xp wouldn't let me proceed because I have FAT32 partition and it's not allowed for a file to exceed the 4gigabytes
that what win xp told me)))
so any help please>>>>
CAESAR -
Select under Video->Direct Stream Copy in Virtualdub or Virtualdubmod or Virtualdub-mpeg2 and you wont get a 7 gigabyte file. Virtualdub will just COPY the file then...if you use something else it will reconvert to an uncompressed video file.
www.videohelp.com/virtualdubedit -
Originally Posted by caesarhawy
Yes, "Direct Stream Copy" should help...AZKaban -
Baldrick wrote:
Originally Posted by Baldrick
then converting them into DVD with WinAVI Converter...(quality is very important)
THANKS THANKS THANKS
CAESAR -
Iv used Easy Video Joiner It mite be shareware but it does no encoding whatsoever and so the quality remains high. (assuming you have the video in good quality)
Reason i like it is because it does what it says it does no encoding whatsoever. -
If you are making a DVD then DONT join your AVI files. Encode each separately by putting your custom mark. Then use your authoring s/w to create your DVD.
FAT32 will not allow to have files bigger than 4GB. Convert to NTFS if you can WITHOUT loosing data.When I was born I was so shocked that I could'nt speak for 18 months.
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 02:09 -
high quality VOB files
By nji899jus in forum Newbie / General discussionsReplies: 29Last Post: 15th Oct 2009, 08:32 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 17:08 -
High quality DVD and HD files, my recommendations
By ensign ricky in forum User guidesReplies: 0Last Post: 30th May 2007, 15:59
