Ok guys so I got the new PC put together and its awesome. I installed windows XP with an old disk, planning to activate it when I received my new Windows XP disk in the mail, and now it wont let me activate it. Every ten minutes or so a little bubble in the corner pops up and says I need to activate Windows XP, but when I click on it the window says "Windows XP has already been activated," and then it pops up 10 minutes later. I tried to deactive it by messing with the registry settings, but I just could not get it to deactive. Do you guys have any suggestions on what I should do? I really would like to activate it, and that bubble is getting annoying.
Tim
Why don't you just do a reinstall with the new disk?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
If you installed XP with the old disc, then you have used a serial number for that disc that has already been activated.
You will need to use the serial number provided with the new disc. -
If you dont want to re-install Windows XP, you best bet will be to contact microsoft.
Waheed is telling you the truth.
Microsoft will walk you through the steps of chaning the serial number. -
How long does the activation status for a CD key last before you can reactivate again on a new machine ?
I've "heard" that after a few months a CD key can be used again. -
Activation is tied on one machine only, regardless of time.
CD Key cannot be used again. If you buy a new PC, then you will need to contact microsoft again to transfer XP from the old PC to the new PC.
Windows Product Activation Stops Logon
By Squid_uk in forum ComputerReplies: 15Last Post: 30th Dec 2009, 08:11 -
Windows XP Activation kicked in, was updating firewire driver.
By vhelp in forum ComputerReplies: 10Last Post: 28th Dec 2009, 18:33 -
meGUI - XviD: Home Theater profile bitrate issues.
By blackflames in forum Video ConversionReplies: 0Last Post: 4th Dec 2009, 09:26 -
Motherboard change windows activation ?
By Illusionist in forum ComputerReplies: 31Last Post: 26th Aug 2008, 05:19 -
home video to dvd: resolution issues
By hickmanbetty in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2008, 11:56
