I am new to converting video files to DVD. I have an ATI AIW 9800PRO video capture card. I have downloaded several movies from TV and
they show as .mpg files. I copied one of the movies to DVD, but it did not play on our home DVD player. Which format, software, and DVD media would serve me best so I can play these movies on our home DVD player? Thanks.
First, look to the left at 'What is DVD'. Those are the specs you will need to match.
If you can capture at those specs, at least the size 720 x 480 pixels MPEG2 or 352 x 480 pixels MPEG2 (Which is better for TV captures) you will reduce the amount of work needed considerably.
Framerate is 29.97 fps. The audio is 48000 Hz.
Once you have a DVD compliant video, all you have to do then is author it and burn it. Sounds easy, but there are plenty of guides to step you though the process. <<<<<<< -
Redwudz,
Thanks for the reply. I will read this information and learn what to do. Will let you later if it works. Thanks again.
Steve
convert mp4 to mpg / DVD (mac)
By tou in forum ffmpegX general discussionReplies: 2Last Post: 29th Aug 2010, 18:57 -
How can I convert a DVD to mpg with subtitle?
By szalaikornel in forum Video ConversionReplies: 4Last Post: 4th Feb 2009, 12:58 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
