  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello everyone, i have this CD and i wanted to get rid of the CD so i copied all files to my comp. but when i run the program, it still asks what drive the CD is in so that it can access certain executable (.EXE) files. my question is how can find a way around this problem and configure it so that i can make the program access the executable files on my comp and not the CD? please help thanks.
    Wow! You got shocks, pegs... LUCKY!
    USA
    Try Daemon Tools. You can mount the CD file as an image and probably can use that to boot the program.
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok is there perhaps a guide that can help me with that? also i heard Daemon Tools has an emulator or something, and my PC games dont play when an emulator is on my comp. so can i disable and enable it regularly? you know wat i mean?
  4. try some software like virtual cd which does copy image on hdd
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    what about CDRWin, i read that it does something similar.
