hi there,
The videos sometimes get stuck up or broken, whether it's a VCD version or DVD version of MPEG movies. I want a software which could fix these errors to ensure smooth running without any hang ups/stuck ups. I already tried out the following softwares--> VCD Gear and All Media Fixer, but, they didn't fix the problem of stuck ups. So, please help me out with a new one.
Sounds more like bad media.
The Simple Multiplex is asking for an Audio Input. I asked for fixing an MPEG movie file which has probably has certainn errors due to which it plays along with a lot of stuck ups. Please suggest a solution.
Have you tried Womble (overground underground) VCR or Video Wizard?..use the >TOOLS>GOP FIXER.....
http://www.womble.com/download.htmNo2: We want Information.
No6: You wont get it! -
yes i tried out even MPEG VCR and MPEG Video Wizard. Infact, both these softwares(belonging to Womble) have the same tool called as GOP FIxer. This tool when operated from either of Womble's softwares was unable to fix the stuck ups/bad frames of the video.
MPEG-4 frame skip problem - any way to fix it?
By TMHKR in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 08:42 -
Scan and Fix a DVD that has some errors
By ppeterr in forum Authoring (DVD)Replies: 5Last Post: 21st Apr 2010, 03:38 -
MPEG-4 into vid editing software looks like shit, how can i fix?
By davidkim in forum EditingReplies: 1Last Post: 8th Dec 2008, 22:44 -
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 10:29 -
MPEG from HDTV2DVD has low volume – how to fix please?
By ChrisU2Edge in forum DVB / IPTVReplies: 2Last Post: 17th Aug 2007, 15:28
