  1. This is a question that I have since quite a few, and since I don't have 2 recorders to test it, I just can ask:
    If you have 2 burners on your PC, and you have 2 different images of movies on your HD, is it possible to burn them at the same time?, ex. image 1 on dvd-burner 1 and image 2 on dvd-burner 2?, or the two burners are just good to make multiple copies of the same image, ex. image 1 on burner 1&2?
    Thanks in advance.
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
    USA
    If you can launch 2 different copies of your image burning program, yes, you can do it. You risk messing up one or the other files and your computer may run short of resources. Burning the same file to 2 burners is even easier, Nero can do that.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    yep, but it definately is a waste..... because someone else asked within the last week and i tested it.... (another story altogether) and it was actually faster to just run one burner at 8X than 2 burner's at 8X because the time it took to burn 2 diff. image's at 8X at the same time was longer than if you just did one 8X burn and then another 8X burn, one after the other than both at the same time...
    But i was waiting to see if the "expert" came in to say what he knew 8)
    and i try to be nice... i really do.... but it's so damn hard sometime's!!!!!!!
