  1. Hey
    I already have an .avi file and made a .srt file using Subrip.
    I would like to force certain parts of the subtitles, but i'm not sure how i should go about doing it. Any help would be appreciated.
    Croatia
    Originally Posted by sangyool
    I would like to force certain parts of the subtitles.
    What do you mean by "to force certain parts..." ?
  3. its for star wars episode iv, when jabba the hut talks to han solo
    the subtitles don't show up
    Dec 2004
    Australia
    If the original DVD has forced subs for that, then you need to enable forced subs only in subrip and process the right stream (the one containing forced subs). At the end you will end up with an srt of only the forced subs.
  5. Originally Posted by celtic_druid
    thanks a bunch i will try that
    so the subtitle will force itself after it has been turned on in subrip?
    Dec 2004
    Australia
    No, it will rip only the forced subs so that the srt contains only them. You can however have a second sub stream containing all the subs. As far as I am aware srt doesn't allow for forced subs.
