I'm sorry if this has been answered before, but I couldn't find an answer to my specific question after a forum search.
I have a problem with sound synching with some of the DVDs I have burned. Although the AVI files have the sound and video perfectly syncrhonized, the DVD will have the sound a few seconds ahead of the video. This can be quite annoying. In the past, I have tried not doing anything while my computer encodes, shutting down all running applications, and out of the last 2 DVDs I made, one had the sound synch problem, and one did not. I use ULead DVD Movie Factory 3, but I also have Adobe Premiere 6.0 (I don't really know much about how to use it though). I have been advised to use VSO DivX to DVD for maintaining aspect ratios, so I was also planning on using that for encoding. If there is some better software that I should use (not hugely expensive though - my wallet is breakable
) that can fix this problem, please let me know.
Thanks in advance!
Results 1 to 1 of 1
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 15:43 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36
