I am using DVDShrink and my speed ramps up to 5000kbs then slows to 2900kbs. The Proccess under the Task Manager show Shrink is taking 95-99 %.
I formatted myHard drive two weeks ago hoping there was a problem there, and installed Norten Internet Security, (4 in 1).
I was on the phone with Dell today and got rid of some stuff and the computer is running faster.
DMA is activated
I just don't I just don't understand why it slows down.
Has this happened to anyone else? What did you do to fix it?
Any advice would be appreciated.
anne
Anne
The application might be finding areas in the file where it can do some heavy duty compression - (eg -areas that don't have much movement and detail). That process is very CPU intensive.
are there any other processes running along with dvd shrink. Is dvd shrink set to run in low priority mode?
Shrink is not set to run in Low Priority Mode
And, yes, there are many other processes running along with Shrink. Thirtyfour in total. They all say 0% CPU usage.
Is the of any help?
anneAnne -
COuld be dirty disks. Even mild disturbance of the surface can slow the read speeds to ensure a clean read.
Try ripping the same didk with DVD Decrypter instead, just to see what happens.Read my blog here.
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 11:07 -
Best way to rip and encode TV episodes to DVD?
By MackSwagga in forum DVD RippingReplies: 8Last Post: 28th Mar 2011, 20:16 -
How to re-encode an upscaled 720p rip
By mysteryman26 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2011, 03:52 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
What software are you using to rip/encode DVDs?
By dbone1 in forum Video ConversionReplies: 2Last Post: 21st Jun 2008, 01:39
