Hi! I'm using Cucusoft Avi to dvd then i use IFO then Nero to burn movies.
Someone told me to use TMPGEnc_DVD_Author & MPEG Encoder they are faster then the software i'm using.
But the problem i'm having is
TMPGEnc_DVD_Author is for windows 2000 and up.I have windows
98.Is there a nother program i can use thats as fast or faster then
TMPGEnc_DVD_Author + Is there anyway to fix the Brightness & Contrast on a movie Cususoft does it but the software takes to long to change the file for Avi to Dvd![]()
================Thank you all for the help===============
You are in breach of the forum rules and are being issued with a formal warning. PLEASE use a subject that describes your topic.
/ Moderator Baldrick
Results 1 to 1 of 1
BadTast
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
