Closed Thread
  1. Banned
    Dec 2004
    SE4
    Are there any program that allow me to safely remove an IDE Hard drive without messing anything up??
    You are in breach of the forum rules and are being issued with a formal warning. Wrong forum. Wrong subject.
    / Moderator Baldrick
  2. Do you mean a second HD?
    If so turn off the PC and disconnect.
    BTW..your boot OS should always be set as master.
  3. Banned
    Dec 2004
    SE4
    yeah im talking about the slave, was just wondering if there was a way to disconnect it without turning the pc off..
  4. You must turn off your PC also turn the power off from that back or unplug it.
  5. Member GeorgeW's Avatar
    Feb 2005
    sounds like you are looking for a "hot swappable" type of connection (no need to turn off PC).
    External drives allow this (I have firewire-400 and USB2 external drives that I can connect/disconnect while the computer stays on)
    Depending on your needs, could you install one of those drive caddy's -- this will let you remove the HD, and put in another one -- you will still have to turn off the computer first...
    here's the type of caddy I am talking about:
    HD Caddy
    George
  6. I would agree that what you are loking for is a drive caddy. I've tried both a caddy and a usb hard drive and both work. Nyah Levi
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    bye.
