Hi, ok. I have an avi file which I made into a nstc DVD using Tmpgenc. I downloaded subtitles for this film but it is in Romanian language whic is a .sub file. Is there a way I can convert this subtitles to English and also see if it is even in sync since I originaly had an .avi file and the subs are from a site? I hope you can answer this..
Thanks, I hope this meets the guidelines for questions..
To check if the subtitle is synchronized with your movie:Originally Posted by averyisiah
1. open that .sub file in Subtitle Workshop and note the frame rate.
2. then click Movie and Open, to open your .avi file.
3. if original frame rate has changed when you open the movie in Subtitle Workshop, just click save.
You can not just convert into another language. Try to find the subtitle in English, or you would have to translate yourself. It's easier than to learn Romanian.
Here is a link for subtitles in many languages:
http://subtitles.images.o2.cz/130/Ms -
Great thanks, i got the english subtitles with a 25 fps rate but my .avi file has been already converted to a dvd with a 29.97 fps rate and I deleted the original .avi, so how can I do this??
Thanks again. -
It is difficult to say now when you do not have the avi.
You should experiment a bit. Just guessing: the original avi was probably in 23.976 framerate, maybe in 29.97.
So open Subtitle Workshop, open your subtitle and change the framerate (on the left) into 23.976, then save as...
You would see if it is in sync with the movie, when you add it during reauthoring. -
Great I will try that.
Puno Hvala, ja cu to probat...
I hope I can still spell, it's been a long time... -
Wow, man.
Thanks for that Croatian. Spelling is excellent! Where that came from?
Hvala tebi, drago mi je da sam pomogao. -
Thank god I can still spell, Hrvatski used to be my first language, I was bor In canada but raised in Hrv. until I was 3,then back to Canada...
But I always go back home to visit almost every year...I noticed your location on your profile so I thought I would just say something for fun...
Overclock Assistance/Advice...
By Moontrash in forum Newbie / General discussionsReplies: 5Last Post: 31st May 2009, 08:10 -
MP4 Playback Assistance
By Madz in forum Software PlayingReplies: 3Last Post: 11th Jul 2008, 12:05 -
I require assistance with a layout, please.
By Zynn in forum Authoring (DVD)Replies: 3Last Post: 5th Feb 2008, 09:39 -
DVD Cam Assistance
By jschramm97 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 23rd Dec 2007, 11:55 -
Video Codec Assistance
By 123fish123 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2007, 07:03
