hello,
I read that the CPU requirement to use TMPGEnc DVD Author 1.6 is 800MHz and HDD format should be NTFS . And for TMPGEnc 3.0 XPress the cpu should be 1GHz.
My computer is a intel celeron at 600mhz and I use FAT32 file system...will the softwares mentioned above work on my computer?
I use Windows XP Professional...
Sure, they will work. The numbers they mention are just suggestions for optimum performance. You setup will just be a little slow, mainly with encoding. However, if you change your drives to NTFS, it will help because of the filesize limitation of FAT32.
Also, if you fill out your computer profile, we would know how much memory and harddrive space you have. Both have a bearing on the performance of the two programs.
TMPGEnc DVD Author vs Xpress
By likwid8 in forum Authoring (DVD)Replies: 6Last Post: 20th Oct 2010, 11:56 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
