I want a green screen and I think the cheapest option will be to buy green fabric from a fabric store. Since I have never seen a real green screen in person, I'm not sure what shade of green to get. What type of material would be best?
Results 1 to 11 of 11
Its far more than color. It's about a tight dot on the vectorscope*. If you want to get serious buy the specfic designed paint and fabric.
http://shop.store.yahoo.com/cinemasupplies/chromkeyfab.html
shop for price.
* i.e. a highly specific peaked hue and chrominance to the exclusion of similar shades. -
yes, i would think the green fabric would contain millions of shades
whereas an equally lighted specifici blue/green screen has a far smaller toleranceSome people are only alive because it may be illegal to kill them -
What you need is something that will show up ON YOUR VIDEO as uniformly the EXACT SAME COLOR THROUGHOUT. It will need to be absolutely flat, no marks, ripples, etc.
This will be difficult to do with fabric. -
http://stores.ebay.com/Elsdon-Enterprises-FX_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
Here's the guy I used...it's the same stuff as the guy in edDV's post except it's considerably cheaper.
One word though, unless you're going to stretch this screen out to make sure it has no wrinkles, you're not going to get a good key. I use Serious Magic Ultra and leave the wrinkles the way they are and the keys still come out better than anything Vegas5 could ever hope for.
Just food for thought. -
Depends if you just want it to look like a chromakey screen or be a chromakey screen.Originally Posted by Tyler2000
Ok, I'll get a real chromakey screen. How about one like this: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=30079&item=7501922263&rd=1
It has blue on one side and green on the other. It has it's own metal frame so I can just lean it against a wall and then fold it back up when I'm done.
Is this a good screen? I will only be playing around with it, but I want it to work. -
I know pinnacle sells a green screen fabric for $20. I have two of them and they work great.
If it were me, I'd start with a more trusted source
like http://www.bhphotovideo.com/bnh/controller/home?O=pagination&A=nextPage&Q=&catId=1&com...4556_REG=&pn=2
and then shop price for the same product.
some are less expensive than the one you found like this
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=288155&is=REG
I've also search user opinions. -
BTW, consumer cameras have more bandwidth in green, so that is the recommended color. Blue optimally requires a 3 chip RGB camera source with RGB outputs..
Here is a good intro
http://www.signvideo.com/ltchromky.htm
Chromakey kits
By proud2b4family in forum Newbie / General discussionsReplies: 0Last Post: 31st Mar 2011, 19:38 -
Where to find moonscape backdrop video for chromakey?
By lboiv001 in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 07:04 -
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 12:48
