Hi when i use svcd2dvd after i have used it once this error comes up the same happens when i restart the computer any ideas
http://img230.exs.cx/img230/4868/error0lc.jpg
ok. This is v1.5?
Do you have the file: msvcp71.dll in your system folder? This is usually c:\windows\system32.
If you do not have msvcp71.dll in your system folder copy it there from the SVCD2DVD folder. Then delete it in the SVCD2DVD folder.
Please let me know how you get on.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
This is usually c:\windows\system32SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:27 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
