Is there any way to encode SVCD's so the DVD player can do the Anamorph/letterbox conversion like with DVD's?
This is no problem if you play an anamorph SVCD on a widescreen TV, then the TV "streches" the picture sideways to correct aspect ratio.
The problem is when using an older TV/proj and it hasn't the possibility to do a horisontal strech or a vertical shrink of the picture.
Where is the information on a DVD, that it sends the player, so it can do the conversion? Is it in the way the DVD is encoded and/or any other information file on the DVD?
Thanks in advance!
Regards,
el-Dia
I'm interested in this information too. i think that the information is in the information file on the dvd. How can we do the same in (S)VCD? Is it possible?
svcd supports the 16:9 flag & you can set it in the stream, but it wont do you any good unless you own a set-top svcd player & that's still only speculation on my part. no hardware or software dvdplayer that i know of recognizes the 16:9 flag
How do I set the 16:9 flag? I am ripping scnes froma movie to burn to dvd-r and I want them to be anamorphic and no 16:9 letterbox.
Is this what i would need to do? -
You'll have load up your normal svcd template in tmpgenc and if it's locked, unlock it. On the first page under Video Stream Setting you have Aspect ratio. I think this is the setting that sets the flag.
Tell me if you get it to work with a normal DVD player. My yamaha doesn't recognize the flag.
Regards,
el-Dia -
It isn't svcd though. It is DVD. I am burning the scenes back to a DVD-R and want them to be anamorphic when they play on my widescreen tv. Right now they are playing in 4:3 letterbox.
Is this what I would need to do so they play correctly? If not...what do I need to do?
PS3 with non-anamorphic DVD
By Pliny in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jul 2014, 09:10 -
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21 -
Anamorphic DVD Recorders?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th May 2008, 15:05
