I am having problems with the sound going out of sync when converting AVI files to MPEG using TEMPGENC Plus 2.5 The way I do it is below which usualy works fine even it is a bit complicated
1) I start of with the AVI file (usualy DIvx) and I decompress the audio using AVI Audio Decompressor 1.4
2) I then use VirtualDubMod 1.5.1.1.a and use full processing mod with DIVX 5.2.1 codec
3) Then I use TEMPGENC Plus 2.5 to givr me the MPEG file using the wizard setings
The sound is in syc in parts 1 & 2 but out of sync in 3. Has anyone any suggestions what is wrong
Audio sync issues seem pretty common when attempting to join parts of a video together. So far I have not seen a good answer to the problem, other than to encode the parts seperately, then author them as a single title in tmpgenc DVD author.
Read my blog here.
Sorry if I didn't make it clear, this is not joining AVI's together just converting to MPEG
Ahh - it was the last sentence that threw me. I use Virtualdubmod to extract the audio to uncompressed wav, then use vegas to create the 2.0 AC3 files for authoring. Never had a sync problem using this method.
Read my blog here.
I looked on my Virtualdubmod and could not find a audio section.
I have used Virtualdub to extract the audio but I haven't used Vegas.
How would I get the 2.0 AC3 files for authoring and then what programs would I use then ( sorry for all these daft questions ). -
Just incase anyone is still following this thread, I solved this problem by using DCD2SVCD. This uses TEMPGENC but does all sorts of fancy things & just spits out the files ready to burn using NERO or something similar. I have tried 4 different AVI files & all have worked fine. It takes a few hours to convert an AVI but I just let it run overnight
Just a note here: anyone trying to encode video+audio with TMPGEnc should download and install "Toolame"
https://www.videohelp.com/forum/archive/t186189.html
https://www.videohelp.com/tools?tool=96 -
Originally Posted by JohnWB"Art is making something out of nothing and selling it." - Frank Zappa
remove a logo without loosing quality
By mathmax in forum DVD RippingReplies: 13Last Post: 9th Jul 2010, 11:54 -
Vegas 9, and HD hero. Loosing too much quality rendering, need help.
By carl1864 in forum EditingReplies: 3Last Post: 26th Mar 2010, 15:54 -
How to get AVCHD on Harddrive of PS3 without loosing quality
By alex1357 in forum Video ConversionReplies: 2Last Post: 7th Jun 2008, 10:06 -
What to use to edit DVD (Video-TS) without loosing (much) quality.
By Scav2003 in forum MacReplies: 2Last Post: 2nd Nov 2007, 10:39 -
iTunes Loosing NBC?
By ssj2_goha in forum Latest Video NewsReplies: 10Last Post: 6th Sep 2007, 02:19
