Results 1 to 14 of 14
  1. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Been working on this for a while, on and off. It's a DVD of my son's 5th birthday. I did one for his sister - video, photos, some downloaded silliness - so I have to do one for him. If I get my arse into gear, I might get it finished before he turns 6.
    Anyway, this is the main into and menu. All done using photoshop and after effects. You can't see it as clearly this small, but I have lifted him out of the photo, repaired the gap in the photo, then used after effects to make it look like he standing infront of the water and the camera is moving around him. It's subtle, but very nice.
    I know it's indulgent to show off, but I get inspired by seeing some the work you guys do (although work isn't posted often enough), so here goes :
    Video (Xvid 882kb, no audio)
    Read my blog here.
    Mar 2005
    Toronto
    all is good however when maximized its kind of blurry maybe you could get a better picture, that has higher quality?
  3. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    I'd love to check it out, but I don't have Xvid or Divx codec installed.
    Maybe try wmv next time. I would guess that would be the most compatable codec, besides mpeg-1.
  4. Member dipstick's Avatar
    Jan 2005
    Just out of curiusity, is it anything like this?
    motion2.wmv
    I made that in Wax2 with the Quick3D plugin. I used two images (dog and background) and animated them in 2D.
    Because of the low bitrate used, the wmv doesn't do the original justice, but you get the effect.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    CrisCross - it's half the size of the original to save download time
    dipstick - you need to be a little more agnostic and try other formats. It is similar, although done manually. Mine came from a single photograph, so I have had to extract the subject (my son) from the photo, rebuild what was behind him, then set it up as seperate layers in AE. I then do a camera pan across the image, using my son as the target. The text lays just use different depths to pass behind or in front of him.
    Read my blog here.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Looks good,bet that takes a lot of work using overlay and the likes.
    Apr 2004
    Miskatonic U
    A couple of hours to get it all in place. There are 6 seperate comps all layered together to give me the most freedom.
    Read my blog here.
  8. Member dipstick's Avatar
    Jan 2005
    Sorry, but I'm a firm believer in only installing codecs that are needed. I have no use for Xvid or Divix, so I don't install them.
    I like that text passing in front and behind on seperate layers idea. I bet it looks cool. I'm sure it gives it more of a 3D effect.
  9. dipstick, yours looks wonderful!
  10. Member dipstick's Avatar
    Jan 2005
    Thanks trock. I just wanted to show what good Freeware can do.
    I also have AE as well but I like to play with Wax2 just for kicks. It operates similar to AE, but not quite as powerfull or as easy. AE has nice grab handles that makes it easy to rotate / swivel images and video. In Wax2, you have to enter every movment manualy with keyframes, but gets similar results. It takes some time to figure it out, but it's well worth it, if you want to create special effects cheaply.
    guns1inger is right on. More people should post some of their work. If nothing else, it gives others ideas.
    Here one that kinda died.but shows up every now and then.
    https://www.videohelp.com/forum/viewtopic.php?p=1125862#1125862
  12. Originally Posted by johns0
    hi,
    not trying to brag here, this kind of stuff can be easily done in Vegas and photoshop...for very complicated ones..after effects is the way to go.
  13. Member dipstick's Avatar
    Jan 2005
    jakol, You're absolutely right.
    It can also easily be done in Premiere Pro. Just create all the layers in Photoshop and save as psd with all layers razterized. Import into Premiere Pro as a "Sequence". You will then be able to animate each layer seperately.
    I did a really cool one for my son's Baseball Team, but I won't post it because it has the players pictures and names.
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Premiere Pro has so much after effects in it now that it should be easy. And yes, it can be done in Vegas, but not a quickly or flexibly. I'm a believer in using the best tools for the job. Yes, I can open a can of spagetti with a screw driver and hammer, but if I have a can-opener, why would I ?
    Read my blog here.
