  1. I am getting this error message "Not Enough Memory" when I try to load .d2v file. Anyone knows what is the problem?
  2. Well, it means exactly what it says. Video files are large and take up a lot of room. When your project exceeds the amount of ram available, it uses the swap file on the hard drive, you may need to increase the size of the swap file and/or clear some space on the hard drive.
    More information would be a big help in answering your question. What is your system, what operating system are you using, etc. Nyah Levi
  3. .d2v only have 3.5 gb, I have 34 gb free space and I got 1gb memory. I want to increase TMPEGnc memory usage, but I don't know how.
  4. Originally Posted by nelson133
    I'd also recommend upping your page file size. I had this same problem when I tried frameserving 6 virtualdub files into CCE. Increasing my page file size fixed the problem.
  5. [/quote)
    I'd also recommend upping your page file size. I had this same problem when I tried frameserving 6 files into Increasing my page file size fixed the problem.[/quote]
    How do I do that?
  6. What OS do you have?
  7. Originally Posted by fmctm1sw
    I have WinXP SP2.
  8. Originally Posted by jydgreat
    I have WinXP SP2.
    Sorry, my memory is failing there. Part alcohol, part the fact I don't have XP. Control panel -> system -> performance options?
