I'm a bit squeezed for space on my latest DVD job here and I'm wondering what is generally regarded as the lowest acceptable AC3 2 channel bitrate? Normally I just stick with 224kbps for AC3 but for this project I could do with having some extra bits in the video instead. I've seen 192kbps on retail DVDs before. What about 160 or even 128? Would I hear the difference?
I've tried 128 & 160 in MP2 and the result was not good. 160 might be acceptable in MP2 if you weren't too fussy but 128 is absolutely hideous with a lot of ringing artifact in MP2.
The audio on what I'm encoding is only actor speech. There is very minimal music. Any recommendations would be greatly appreciated.
Results 1 to 12 of 12
i got to 160kbps in stereo AC3 all the time. I think this is the lowest that i find acceptable. The sound difference between 128kbit and 160kbit is greater than it is between 160kbit and 192kbit. If it is just speech, then 160kbps is fine.
If you have a 5.1 channel encoder, like the one that is in vegas, then you could even do mono though, and you can go down to 96Kbps. Though, mono is unfortunately mono.Some people are only alive because it may be illegal to kill them -
If it is for you, then acceptable is what you are willing to put up with. There is another thread running at present where the poster is happy with 40kbps MP3 audio and sub-VCD video. Each to there own. If it is for someone else, then I wouldn't go below what the commercial disks use.
Personally, I use 192 for 2 channel, and 384 for 5.1Read my blog here.
Do it at 224, then compile and run the whole thing through DVD Shrink
Cheers, Jim
My DVDLab Guides -
I think that the "official" recommendation for 2.0 AC-3 is a bitrate of 192kbps
Most commercial DVD discs use 192kpbs for 2.0 AC-3 although I have seen some use 224kbps and even 256kbps
Almost all stand alone DVD recorders use 256kbps 2.0 AC-3
So I wouldn't go below 192kbps myself.
Personally I always use 256kbps when working with my captures etc.
160 should be fine for your application, just simple voice recording. If it was very 'busy' audio such as an action movie or a sporting event then 160 would be pushing it a bit.
Originally Posted by guns1inger
Originally Posted by reboot
You're saying two generations of encoding will ultimately result in a better quality end result that the same thing encoded once? -
Almost all stand alone DVD recorders use 256kbps 2.0 AC-3 -
Unless we're talking somewhere in the XVCD/VCD range for your video bitrates (less than approx 1000kbps give or take), IMO you're not gonna gain a helluva lot even with an extra 100kbps or so for the video. I've only even seen 192kbps 2ch AC3, but being a fellow oztralian I normally just stick to 192kbps MP2 anyway.
If in doubt, Google it. -
Not quite that bad but I am in the CVD bitrate sorta range and the audio bitrate I choose will determine whether it's < or > 2000kbps for the video.
2000kbps is a bit of a psychological barrier for me. <2000 will mean I make it CVD resolution. >2000 means I consider using SVCD resolution instead. So yeah there was a little bit riding on the audio bitrate.
As it ended up I used 160kbps for the audio bitrate which meant a video bitrate >2000 but it was only just >2000, so for the sake of full DVD spec compatibility I chose to stick with CVD resolution anyway.
Source image format is not acceptable (VDMOD, XVID, AC3)
By stlolth in forum Video ConversionReplies: 8Last Post: 23rd Aug 2010, 10:22 -
What is lowest possible working bitrate for 5.1 surround?
By Anonymous5394 in forum Newbie / General discussionsReplies: 8Last Post: 27th Apr 2010, 15:16 -
AC3 2 Channel
By mabrandt in forum AudioReplies: 1Last Post: 29th Oct 2009, 08:15 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 13:06
