http://forums.us.dell.com/supportforums/board/message?board.id=dim_other&message.id=219360
Seems Dell is having a lot of problems with the PSUs in some of their computers. And big surprise, but they are not only ignoring the issue but misdiagnosing it, forcing many people to buy overpriced replacement mobos instead.
Just thought this was newsworthy myself. If anyone is having similar issues it's something to be looking out for. Sign up for the petition if you are one of the unlucky many.
Results 1 to 15 of 15
good to know about
This is old news regarding DELL power supplies. There was a link I used to have that explained that dell used non standard atx power supplies. There were people who changed ps unknowningly and fried their motherboards or entire pc. When I find it I'll post it.
EDIT: Ok I found that article here is the link:
http://www.quepublishing.com/articles/article.asp?p=339053
Although this article was done years ago it still is apparent that Dell uses non standard atx power supplies thus having the consumer purchase a new power supply from them which cost much more than going out to a local pc shop or online retailer. -
Not so in this case. I know many of their models use cross-wired PSUs but the one in the 4600 uses standard ATX connections and with the open back on the case can be swapped out for any PSU really. They've started using ATX PSUs in many of the newer models from what I've heard.
Another reason I will never buy a factory PC ever again:
1.Don't know who makes the hardware.
2.No Windows CD,must use stupid recovery CD.
3.They add trial software that eventually has to be removed.
4.The PSU's are usually cheap and underpowered. -
moviegeek
that is the best post ever describing prebuilt pc's those are the same reasons why i refuse to buy a snell or an Ecrap.. -
I forgot to add:
5.Stupid plastic faceplates on front of case.
If you need a new PSU this calculator will help:
www.jscustompcs.com/power_supply/ -
Originally Posted by MOVIEGEEK
As I explained to a newby one time, "you may not save any money when building your own, but you won't try to slip a junk component into the box to increase your profit margin." Nyah Levi
Dell has been using standard PSU's for a while now. What I have seen myself, and read about. The fact that they are dying is typical of a cheap component. No surprise.
Misdiagnosing the problem? Yeah, that's bad.Want my help? Ask here! (not via PM!)
Originally Posted by waheed
Yeah dell is basing their diagnosis solely on the diagnostic lights on the back. when the light indication power is on they automatically say it must be the mobo. But that light will come on with a very minimal amount of power. You could have all but one rail out and still have enough power flowing to light it up.
Originally Posted by dvdashot
From experience at a large (ish) Australian Company (if you call 1500 desktops large), and using Optiplex GX150 (the model at the time of the refresh) we would replace 3 - 5 PSU's a week, usually after 18 months or so use, but the odd ones were dying after only months in use (what do you expect when the PSU is only rated at 90W for a PIII !!!!)
Problematic interlaced source (missing/dupped fields)
By Dogway in forum RestorationReplies: 6Last Post: 4th Feb 2012, 20:19 -
How to Make ( problematic or something) DVD Seekable?
By devilcoelhodog in forum Authoring (DVD)Replies: 0Last Post: 18th Sep 2009, 20:55 -
How to convert problematic video file?
By gtracs in forum MacReplies: 5Last Post: 3rd Aug 2009, 23:32 -
Problematic mpeg2 file
By Caple in forum Video ConversionReplies: 3Last Post: 4th May 2009, 19:03 -
64 bit op systems
By dblake2 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2008, 16:44
